Zaim
Jan 23, 2013Aspirant
MKV showing as MPEG via DLNA
Hi, I purchased the Netgear NV+V2 NAS, I have copied a few MKV's and M2TS files to test it works via my Sony BDP 490, now the MKV files wont play, interestingly these files show up as MPEG on the blu-...
Zaim
StephenB wrote: I am not sure if that will work, the thread is pretty old.
You could try remuxing the MKV with the current version of mvkmerge GUI. This is part of the mkvtoolnix package; there is a link here: http://www.videohelp.com/tools/MKVtoolnix
Go into options and check "disable header compression removal for audio and video tracks by default".
Thanks, I'll give that a go, I have also emailed netgear about this. Hopefully they will sort it.
Edit: that didn't work, here's the settings I used:
set compression to none for the audio aswell.
