Zaim
Jan 23, 2013Aspirant
MKV showing as MPEG via DLNA
Hi, I purchased the Netgear NV+V2 NAS, I have copied a few MKV's and M2TS files to test it works via my Sony BDP 490, now the MKV files wont play, interestingly these files show up as MPEG on the blu-...
Jan 23, 2013Guru - Experienced User
That is the correct procedure, so the issue probably isn't the MKV itself. The MKV looks pretty ordinary.
Zaim wrote:
Edit: that didn't work, here's the settings I used...
set compression to none for the audio aswell.
