gpaolo
Aug 01, 2013Luminary
Move disks from Duo V2 to RN314
Hello, I would like to know if it is possible to move the disks from my old ReadyNAS Duo V2 to the new RN314. Thanks!
vandermerwe
Aug 01, 2013Master
No that's not the safest way unless you are proposing making 2 copies of all the data.
If you only have a single copy of the data at any particular time, then your data is vulnerable. You should always have at least 2 copies of the data, particularly if it is irreplaceable. You should also keep an offsite backup of either all the data or that which is most valuable/irreplaceable.
