gpaolo
Aug 01, 2013Luminary
Move disks from Duo V2 to RN314
Hello, I would like to know if it is possible to move the disks from my old ReadyNAS Duo V2 to the new RN314. Thanks!
vandermerwe
Aug 01, 2013Master
I am still not certain that the readynas will add the disk to the raid array if it has been previously formatted. Ŷou could try this, add 1 disk, factory default, copy data, power down, remove disk. Add 2nd disk, power on, factory default. Power down, remove disk 2, insert disk 1, power on, check volume is ok, then hot add disk 2.
It is easier to just delete the partitions with a PC- do you not have a usb:sata caddy or a USB:sata cable (one of the most useful tools I own.)
