Jmeyer00
Feb 11, 2020Aspirant
Move Drives From RN2120 to RN3138
We have an RN2120 with four 8 TB disks. This unit has been a bit flaky for a few months, and this week has started to fail regularly. I do not think the disks are faulty as the problem followed the c...
- Feb 11, 2020
Hi Jmeyer00,
Yes, it is possible to move the 4x8TB disks from the RN2120 to the RN3138 without data loss since both systems are running on OS6. If you have any apps installed on the RN2120, those apps might not work when you move the disks to the RN3138 because you are migrating from an ARM-based unit to an Intel-based unit. You should at least uninstall the apps first then just install the x86 version of the app after the migration.
It will also be best if you do a full backup before the migration just to be safe.
You may also check this article for reference on OS6 to OS6 disk migration.
JohnCM_S
Feb 11, 2020NETGEAR Employee Retired
Hi Jmeyer00,
