edkedk
Dec 14, 2016Tutor
Move HDDs from dead NV+ to another?
Hi, We have a ReadyNAS NV+ (RND4000 v3) that suddenly died. Does not power up. We also have another NV+ (RND4250) that is not in active use. The 4250 has RAIDiator 4.1.7 [1.00a043], the 4000's fw...
- Dec 15, 2016
edkedk wrote:
I don't know the fw version on the dead unit.
Should I do anything on the working unit before removing the disks and putting in the ones from the dead unit?
I'd install 4.1.15.
edkedk wrote:
Are settings like IP address, defined shares etc. going to be inherited as disks are transferred?
Yes. All the settings are kept on the disks themselves.
Dec 14, 2016Guru - Experienced User
That will work, but if the firmware on the spare isn't 4.1.7 then 4.1.7 will be installed onto the disks.
So you might want to install a scratch disk on the spare first, and install the firmware you want there.
- edkedkDec 15, 2016Tutor
Thank you.
For example delete existing shares, resetting all settings...?
- StephenBDec 15, 2016Guru - Experienced User
I'd install 4.1.15.
I proceeded accordingly.
The device works fine, kept all settings. Also, firmware was carried with the disks, so it is 4.1.14 as it was on the dead unit.
Thank you again.
