Spanna's avatar
Spanna
Moving disks to new chassis - Power ON or OFF?
Hi. I am just about to attempt moving a disk to a new chassis and retaining settings and data. I've read this topic... https://community.netgear.com/t5/Using-your-ReadyNAS/Moving-drives-to-a-new-ch...
  • mdgm-ntgr's avatar
    Jun 14, 2018
    Great question both of the chasses should be off. Removing disks while the NAS is on (hot swapping) is for replacing a failed disk or disk you no longer wish to use (i.e. don't care about any data on it) with a new disk.
    It is advisable where possible to put a scratch disk (disk that will be wiped) into the new NAS, update the firmware to at least as new as what was running on the old unit, verify the update is successful, power down, remove scratch disk and migrate disks across keeping the disk order the same.
ProSupport for Business
