jackaninny
Nov 06, 2011Aspirant
Moving from ReadyNAS NV to Pro 6 - Best plan?
I'm getting ready to move over to a new Pro 6 from our existing NV unit. Current NV unit is running 4.00c1-p2 firmware and has about 800GB of data stored on it. What is the best method of moving da...
tenney
Dec 21, 2011Aspirant
Thanks, mdgm.
If I backup from NV+ "A" to the Pro, and then backup from NV+ "B" to the Pro:
(a) will NFS (and then rsync) add files and folders from "B" that weren't copied over from "A"?
(b) will it delete any previously copied over files/folders?
(c) how will it handle things if a file or folder exists on both "A" and "B"
