jackaninny
Nov 06, 2011Aspirant
Moving from ReadyNAS NV to Pro 6 - Best plan?
I'm getting ready to move over to a new Pro 6 from our existing NV unit. Current NV unit is running 4.00c1-p2 firmware and has about 800GB of data stored on it. What is the best method of moving da...
tenney
Dec 21, 2011Aspirant
mdgm wrote: However for some things like the Easy Time Machine share (http://www.readynas.com/TimeMachine) the backup job needs to be on the source NAS.
I didn't see where in that link that it talked much about moving the TM bundle from one NAS to another. However, your response in topic http://www.readynas.com/forum/viewtopic.php?f=71&t=57771 talks about creating a share on the destintion NAS, backing it up to there, then in admin frontview moving the bundle around.
Is that how you'd still suggest moving the TM bundle?
And... since I'm combining two NV+'s into one Pro6, I'm thinking of expanding the TM bundle to allow multiple Macs to backup to it. Am I correct that I'll have to basically create a new larger bundle and then manually copy files from the old smaller bundle over to the new larger bundle -- perhaps combining this with the backup from the NV+ to a special share, then copy files from that bundle to the c/.timemachine bundles? Or is there some other / better way to expand that size of a TM share while retaining previous TM data?
(thanks!)
