jackaninny
Nov 06, 2011Aspirant
Moving from ReadyNAS NV to Pro 6 - Best plan?
I'm getting ready to move over to a new Pro 6 from our existing NV unit. Current NV unit is running 4.00c1-p2 firmware and has about 800GB of data stored on it. What is the best method of moving da...
mdgm-ntgr
Dec 21, 2011NETGEAR Employee Retired
I still suggest moving the same way.
You have separate bundles for each Mac. Providing you're running 10.6.4 or later (I think) the sparsebundles will automatically expand to have the new limit when you've set a higher quota and next do a TM backup.
