jackaninny
Nov 06, 2011Aspirant
Moving from ReadyNAS NV to Pro 6 - Best plan?
I'm getting ready to move over to a new Pro 6 from our existing NV unit. Current NV unit is running 4.00c1-p2 firmware and has about 800GB of data stored on it. What is the best method of moving da...
mdgm-ntgr
Jan 05, 2012NETGEAR Employee Retired
So that worked fine?
You might want to contact NetGear tech support (http://www.readynas.com/support) and see if they have some suggestions.
If you like you could run my TimeMachineLog add-on: http://www.readynas.com/forum/viewtopic.php?p=239030#p239030 and PM (Private Message) me the output.
