Wertster
Aug 17, 2014Aspirant
Moving from RN104 to RN312
I've been really unhappy with the RN104 I purchased just over a month ago. The initial installation was really simple and I put in 2 x 3TB WD Red WD30EFRX RED SATA 6Gb/SE drives to start with. Problem...
Aug 17, 2014Guru - Experienced User
By following the instructions on pages 31 and 32 of the hardware manual, conveniently downloadable from support.netgear.com :shock:
Wertster wrote: Sorry one final query - how do I initiate an OS reinstall on the 312 unit?
The link is http://www.downloads.netgear.com/files/ ... ct2013.pdf It is simpler on the 4 and 6 bay units, the LCD lets you avoid counting the blinks.
BTW, if you need HD transcoding you should get an RN500 series system.
