Lauri's avatar
Lauri
NAS 102 has began to warn about lacking of capacity,
My Netgear NAS 102 has began to warn about lacking of capacity, The message are: "Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current perfo...
  • StephenB's avatar
    Feb 20, 2017
    Lauri wrote:
    What are/means snapshots ? I could not find any when I studied the explorer.
    http://kb.netgear.com/23353/How-does-my-ReadyNAS-OS-6-storage-system-use-snapshots-to-protect-my-data?cid=wmt_netgear_organic
    "Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. ...
    But, when i look at Explorer how much the NAS have used and free capacities, so sitution are following:
    - Used capacity are 145 GB
    - Free capacity are 781 GB
    - Total capacity are 995 GB
    Are you running 6.6.1 firmware?  If so, either turn off the AntiVirus protection, or upgrade to the 6.7.0 beta firmware.
ProSupport for Business
