SARN
Sep 14, 2020Aspirant
NAS Lost Volume Data
Currently having an issue accessing the Data on my ReadyNAS. Currently configured to have Backup data copied to this every night, hover last night this stopped working. Logged into the Web UI and fr...
Sep 14, 2020Guru - Experienced User
SARN wrote:
Logs on the device show:
Sep 14, 2020 01:00:32 AM Volume: Volume data is Dead.
Sep 13, 2020 02:54:36 PM Disk: Disk Model:TOSHIBA MG03ACA400 Serial:XXXXXXXXX was removed from Channel 4 of the head unit.
This of course was the issue. Did you remove the drive?
Possibly also download the full zip file, as with XRAID you'd need to lose two drives.
SARN
Sep 15, 2020Aspirant
Good morning Stephen,
Any help on this is greatly appreciated.
Sep 13, 2020 02:54:36 PM Disk: Disk Model:TOSHIBA MG03ACA400 Serial:XXXXXXXXX was removed from Channel 4 of the head unit.This of course was the issue. Did you remove the drive?
Thank you for the reply. Unfortunatley I did not remove the drive, and this is showing as online on the device.
When you say "Download the Full Zip File" do you mean the Config. If that's the case then yes I did.
- StephenBSep 15, 2020Guru - Experienced User
No. I mean download all the log zip file (which you do from the logs page).
I am thinking some other disk must also have failed sometime in the past. So I'd begin by looking in disk_info.log at the disk health, and also look in system.log and kernel.log for disk errors.
I'd also test the disks in a Windows PC (connecting them with either SATA or a USB adapter/dock). Use vendor tools (Seatools for Seagate, Lifeguard for Western Digital), and run the full non-destructive test.
Power down the NAS before removing disks (and keep it powered down until you reinsert them). Also, label the disks by slot as you remove them so you can put them back.
FWIW, if you don't have a backup of the data you are probably looking at data recovery.
- SARNSep 25, 2020Aspirant
Tried all of that. Have had to just delete any volume reminants and format the drives and start from scratch.
