Rockman
Feb 03, 2015Aspirant
NAS PRO BE no longer seeing Volumes and Shares after adding
As the original 4x500GB disks died, I've been replacing them with 1TB Seagate (ST1000DM003-1CH162) disks over the course of the last year or so. Over the weekend, I added another 1TB Seagate dick to ...
Feb 03, 2015Guru - Experienced User
4.2.27 is the current firmware. I'm confused on the "one I removed to check the type (it appears to be on perpetual resync)" remark. This was removed before you added the Seagate? When did you remove it - before or after you inserted the new drive? The new disk was an add, or a replacement?
If you need the data back, you should try paid support.
