cwalker
Dec 15, 2016Aspirant
NAs RND-4C daily and quartly backup failing.
NAS device has been backing up to two seperat removable HD units. One for quarterly back up (plugged in when needed) and the other for daily backup which remains continually connected. Recently the b...
- Dec 15, 2016
Connected drive to my PC and I can save files to the backup drive just fine. Element drive not set to read only.
Dec 15, 2016Guru - Experienced User
How are the drives formatted? Sometimes the "dirty" bit can get set on the disks, and then they are mounted read-only. If they are formatted so a PC can read them, then connecting them to a PC is the easiest way to repair them.
cwalker
- StephenBDec 15, 2016Guru - Experienced User
If the "dirty" bit is set, the PC will ask you if you want to repair it. If you say yes, it will do a file system check/repair and clear the bit. If that didn't happen, then your issue is something else.
Any specifics on the error in the backup logs?
- cwalkerDec 16, 2016Aspirant
My company has decided to just replace the unit. Thanks for your help.
