Pel_123
Aug 06, 2016Aspirant
NAS slowing down network devices
I have RN10200 NAS ,but it is not working smoothly in my network. I have both XP and Win7 O.S within the network. My entire network slows down whenever i access NAS, kindly suggest any sulution.
mdgm-ntgr
Aug 06, 2016NETGEAR Employee Retired
Which firmware are you running?
Which services are you running under System > Settings > Services ?
Which apps do you have installed?
In what way do you access the NAS when the network "slows down"?
When you say your "entire network slows down" does this mean that two devices that are not contacting the NAS slow down as well?
Is your PC connecting to the NAS, connected to the network via ethernet or Wi-Fi? What about the other devices whose network connection "slows down"?
- Pel_123Aug 06, 2016Aspirant
Hi there,
My firmware is 6.4.0
Services running are (SMB, AFP, NFS, FTP, READY DLNA, UpNP, HTTP, HTTPS , SSH , Antivirus)
No Apps are installed
i Access it from one of my PC in same network which have NAS
The devies which uses NAS Slows down, but devices which does not uses NAS works properly.
All my network is connectd through ethernet, devices that slows down also are connected through ethernet.
- mdgm-ntgrAug 06, 2016NETGEAR Employee Retired
Can you update the firmware and see if you still have the problem?
