chopperead
Apr 08, 2013Aspirant
NAS to front USB HDD backup keeps freezing
I am continuosly having issues backing up 500gb of data from Readynas Duo V1 to an external HDD. I am trying to do full backup of C but every time it seems to start ok but when i come back in the m...
chopperead
See log below i presume this was what your after ? I have looked into the backup job log and it says none exist.
I know the disc has errors which is why im trying to get the data backed up. I had a power surge which took out the other drive so i am currently in need of this backup to work.
Mon Apr 8 19:16:05 WEST 2013 System is up.
Mon Apr 8 19:15:43 WEST 2013 A previous run of backup job is still running. Check if that backup job has stalled, or you may need to adjust the backup interval to account for the amount of data you are backing up. [Job 006]
Mon Apr 8 19:14:07 WEST 2013 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Sun Apr 7 04:00:21 WEST 2013 Disk 1 did not pass SMART self-assessment test. Please replace this disk as soon as possible. Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Sun Apr 7 00:40:40 WEST 2013 Backup started. [Job 006]
One of my previous attempts
Wed Dec 5 22:07:33 WET 2012 System is up.
Wed Dec 5 22:07:16 WET 2012 A previous run of backup job is still running. Check if that backup job has stalled, or you may need to adjust the backup interval to account for the amount of data you are backing up. [Job 006]
Wed Dec 5 22:04:57 WET 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Tue Dec 4 11:57:41 WET 2012 Backup started. [Job 006]
- Jan 17, 2024Retired_Member
