AlisterFiend
Jul 24, 2015Aspirant
Need help creating a Virtual Host to forward web requests to another port
I am using my ReadyNAS to run Plex Media Server. In order to serve media to my Apple TV I use PlexConnect to interface between my ATV and Plex. It traps calls to trailers.apple.com allowing my media ...
- Jul 26, 2015
Generally speaking, what you'd need are VHosts looking roughly like this:
<VirtualHost *:80>
ServerName trailers.apple.com
ProxyPass / http://192.168.2.4:81/
ProxyPassReverse / http://192.168.2.4:81/
</VirtualHost>
<VirtualHost *:443>
AllowCONNECT 8443
ProxyPass / https://192.168.2.4:8443/
ProxyPassReverse / https://192.168.2.4:8443/
</VirtualHost>
Maybe you also need to add "ProxyPreserveHost On" to the statements above. For proxying to work it doesn't matter whether the target is on the same or on a different host. Most examples just use a different host because that's the most common use case.
Your major problem, however, will be to redirect requests for "trailers.apple.com" to the ReadyNAS in the first place, e.g. to make your ATV actually send the requests to the ReadyNAS. For that to work you'll either need a local DNS server and tell the ATV to use that one instead of whatever DNS server it is using by default or you need to add an entry for your ReadyNAS's IP to the local "/etc/hosts" file on the ATV.
miels
Aug 25, 2015Tutor
I try to do something similar. Without touching my firewall / routing tables I'd like to be able to access several apps from the outside.
- I can access the ReadyNas at https://home.myname.com (which redirects to the admin page)
- I have several apps (like SabNZBd, Symform) that can be reached from within the LAN via http://mynas:<port>
- I want to access those apps from the outside, for example via https://home.myname.com/appname on the default port (443 in this case)
I guess something like this should be added to a VirtualHosts setting:
AllowCONNECT 59234
ProxyPass /symform http://127.0.0.1:59234
ProxyPassReverse /symform http://127.0.0.1:59234
I've tried several files to add this code. Something did change when I added this in /etc/apache2/sites-enabled/000-fv-https (and restarted the apache service afterwards), but unfortunately I got a 501.
(How) can this be done?
Bonus question: What are the security risks / how to avoid those?
Aug 25, 2015Guru - Experienced User
I'll pass on this one. Presently I forward ports in the NAS, and I am moving towards OpenVPN. If I wanted to do this with a DDNS service, I'd probably go with a paid service that can forward 443 traffic to other ports (with a different DDNS name for each). Then forward those other ports in my router. Much easier than messing with the apache configuration, and less likely to create problems when updating firmware, etc.
The main security risk is that the attack surface expands to include all the apps you expose. All their vulnerabilities (whatever they are) are exposed to the internet. The only way to really avoid this is to use a VPN - then the attack surface is just the VPN. Weak encryption, and most other vulnerabilities are easier to prevent if you do that. All that's preventing me from going to OpenVPN 100% is the lack of mobile device support (TUN) in the Netgear router's openvpn package.
