mumblingsages
Jul 26, 2015Aspirant
Need help finding a bottle neck
Recently bought a diskless version of 3130 ReadyNAS. At this point I've only installed one drive (don't ask, more are on the way). The drives I'm putting in are 4TB WD Red Pro. I've updated to latest...
mumblingsages
UPDATE
I wanted to eliminate the HD in the mac mini as the potential source. So I created a 4GB RAM disk on the Mac Mini and copied the same file there. I then copied the file from the RAM disk to the ReadyNAS AFP share. Essentially the same result 0:03:36.12.
mdgm-ntgr
Jul 26, 2015NETGEAR Employee Retired
Which firmware are you running?
Is the LUN thin/thick?
Is bit-rot protection enabled/disabled?
Do you have snapshots enabled?
Are Sync Writes enabled/disabled?
- StephenBJul 26, 2015Guru - Experienced User
Also, it would be useful to include read results, not just writes.
Maybe after you respond to mdgm's queries you could try a direct connect test?
Connect the ethernet cable directly between the NAS and the apple PC (no crossover is needed).
If the NAS is using dhcp, then it will default to 192.168.168.168. You'd need to temporarily set a compatible address on the Mac (for instance 192.168.168.100).
Then repeat the test (using IP addresses, not device names).
- mumblingsagesJul 26, 2015Aspirant
Well.... I think we can chalk this up to another PEBKAC / DSU issue. This morning while preparing to run the read tests that were asked for, I discovered that my wiring diagram was not quite correct. Turns out the Mac Mini was wired to the AirPort Extreme base station and not the switch next to the NAS. I corrected that and retested. I'm now moving 2.4GB in just under 24 seconds!! Much happier!
I have a 1GB switch next to the AirPort Extreme. It's showing an uplink speed of only 100MB. So I'm pretty sure its the AirPort extreme that is the bottle neck. Next thing to do would be to figure out why thats not 1GB as advertised but that's not anyone's problem here.
Sorry for wasting your time!!!
- mdgm-ntgrJul 26, 2015NETGEAR Employee Retired
Some older Airport Extreme Base Stations don't have gigabit ethernet. For instance some have Fast (i.e. 100Mbit) Ethernet.
What do you intend to use iSCSI for? Depending on your use case you may/may not wish to use features such as Bit-rot protection and sync writes.
Firmware is 6.2.4
Thick provisioned
Bit-rot enabled
No snapshots
Sync writes is enabled.
