mumblingsages
Jul 26, 2015Aspirant
Need help finding a bottle neck
Recently bought a diskless version of 3130 ReadyNAS. At this point I've only installed one drive (don't ask, more are on the way). The drives I'm putting in are 4TB WD Red Pro. I've updated to latest...
mdgm-ntgr
Jul 26, 2015NETGEAR Employee Retired
Which firmware are you running?
Is the LUN thin/thick?
Is bit-rot protection enabled/disabled?
Do you have snapshots enabled?
Are Sync Writes enabled/disabled?
Jul 26, 2015Guru - Experienced User
Also, it would be useful to include read results, not just writes.
Maybe after you respond to mdgm's queries you could try a direct connect test?
Connect the ethernet cable directly between the NAS and the apple PC (no crossover is needed).
If the NAS is using dhcp, then it will default to 192.168.168.168. You'd need to temporarily set a compatible address on the Mac (for instance 192.168.168.100).
Then repeat the test (using IP addresses, not device names).
