bw23198
Jan 11, 2023Aspirant
Netgear OpenVPN bug
After troubleshooting OpenVPN issues for the past few days; I figured I'd share my results to save somebody else the headache in the future. Here's what I found... I recently installed a Nighthawk ...
Jan 12, 2023Guru - Experienced User
FYI, this is in the wrong forum area (ReadyNAS, not Nighthawk routers).
bw23198 wrote:
After LOTS of troubleshooting I noticed that the router seems to hand out 192.168.2.X IP addresses to VPN clients. The problem was that I changed my router's LAN settings to also use the 192.168.2.0/24 address space.
FWIW, I use 10.0.0.x addresses myself, and have no issue with OpenVPN. That's not to say your info is wrong, just that it does work ok with the subnet I use.
- bw23198Jan 12, 2023Aspirant
Oops. Thanks! Moved here: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Netgear-OpenVPN-bug/m-p/2286716#M225516
