Hofmann1's avatar
Hofmann1
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a format if possible. I need help either fixing the ReadyNAS device so it will read the disc correctly OR access the disc with my data some other way that through the ReadyNAS.
Long version: I've recently gotten a new NAS device, upgrading my ~3 year old ReadyNAS Duo to another 2bay NAS. My harddrives are 2x Seagate 3TB NAS drives, none of which has ever been in any raid config. I'm using a HP Probook laptop running Win8 with all relevant software updated. At the moment I don't have access to a desktop rig to try to collect the data that way.
Disk 1 has only been installed in the ReadyNAS and contains all my backup data.
Disk 2 has only been installed in the new NAS and contains no data.
I suspect that the ReadyNAS is somehow failing, while the hard drives are most likely OK.
My problem is that my ReadyNAS does'nt work properly, and it's seemingly the only device I have able to access the data on Disk 1 (atleast when the ReadyNAS is functioning properly). This is likely because of the ReadyNAS formatting the drive upon installation, which implements a partition system my other devices won't recognize. Not even my WD external harddrive "shell", which originally had a 1TB drive in it, will allow me to access it. The disc manager tool in windows detects the disc, which holds about 3-4 partitions but with no (recognized) file system.
With Disk 1 inserted in the ReadyNAS and turned on, I can locate it using both RAIDar and windows explorer. (I find it odd though, that win explorer lists the NAS twice in explorer - one using the NAS IP address and one using the Netgear-style Host name.) I can however only access the root folder of the drive, containing the default Netgear folder Media and Backup. When trying to enter any of the folders in the root directory, I get the standard windows timing out "cannot access 10.10.0.999/media" file/destination error message. This happens when the drive is installed in either one of bay 1 or bay 2.
The problem started a while back, when I suddenly was unable to turn the ReadyNAS off the normal way - I ended up having to pull the power cord to kill it. Since then I've been unable to access the data on the disc.
Any guidance is appreciated.
  • StephenB's avatar
    Ok.
    -we know this is a v1 for sure
    -we know it had a 3 TB inserted, even though this NAS doesn't support 3 TB drives. The volume size would have been < 1 TB.
    Linux Reader on drive 1 might work. But it is possible that that the 3 TB confusion might result in linux reader misbehaving.
  • As far as i can remember, the 3TB drive was working fine and at normal capacity even though it's in a v1. I might be wrong, I never expected this to happen so didnt take note.
    LinuxReader can find the drive, with its 3 partitions. They seem to be empty... Not sure what this means.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    We use EXT3 and the partitions should be much bigger.
    I'm sorry, what does that mean? The partitions should be bigger yes, 1 is on 1TB, 1 on 360MB and 1 on 450mb.
    I'm having a hard time figuring out why the NAS worked flawlessly with this too larget disc for a while, and now it doesnt
    mdgm-ntgr
    Was the disk used somewhere else before being used in the NAS?
    The data recovery software might be seeing partitions from when the disk was used somewhere else previously.
  • StephenB's avatar
    I was thinking that also. I know that the duo would only see a small fraction of the 3 TB drive, but I don't know exactly what part it sees/formats. If the disk is used, there certainly would be residue in places the duo didn't know about.
    if you had an old PC that also didn't have bios support for 3 TB drives, then perhaps linux reader would work on that machine???
  • I dont have any more ideas, unless you can find another duo v1 and try the disk in their.
    Perhaps you can mount the disk in a minus pc or if you install a Linux OS on your PC?
ProSupport for Business
