BMDConsultants
Feb 20, 2017Initiate
Netgear RN102 extremely slow after OS 6.6.1 firmware update.
Hi, I'm having issues loggin in to the admin page of my Netgear RN102. It is extremely slow after OS 6.6.1 firmware update. Is anyone else experiencing this? Regards, Brett
- Retired_MemberFeb 20, 2017
RN10X seem to be a bit overwhelmed by the newly integrated Antivirus service. If that service is currrently enabled on your machine, try to disable under settings and hopefully see your box reverting to normal performance.
evan2
Feb 22, 2017NETGEAR Expert
Make sure connect your NAS to Internet, then reboot NAS, it will automatically download a patch to fix some issue for new Antivirus service.
- BMDConsultantsFeb 22, 2017Initiate
I disabled the antivirus as recommended. That was definately the issue. I will have a look at the patch. thank you.
