Starlionblue3
Jan 26, 2016Tutor
Network performance slowdown after a few hours
I have a ReadyNAS NVX connected to a Netgear GS108T smart switch through two CAT6 cables using link aggregation with LACP on the switch. The ReadyNAS ports are set up as 803.2ad LACP, with Layer 3+4 ...
Jan 26, 2016Guru - Experienced User
What firmware are you running? Also, what OS is the PC running?
FWIW, the bond will not increase your single-user speeds, so you could try disconnecting one of the cables and see if that makes any difference. My guess is that it won't though.
- Starlionblue3Jan 26, 2016Tutor
Yep, I tried single cable. No difference. I've tried connecting with only one switch between PC and ReadyNAS as well with the same results. Right now I'm running a Netgear GS108T smart switch for the NAS, connecting with two cables (LACP with RSTP) to a Netgear GS716T smart switch which connects to the PC.
Maybe it has something to do with the networking between the switches, but that wouldn't explain why restarting the ReadyNAS fixes it. Or?
ReadyNAS firmware is 4.2.2.28, and I'm on Windows 10. However I had similar problems in Windows 7 and 8.1, but they didn't appear as "reliably" as now.
Model: ReadyNAS NVX Business Edition [X-RAID2] Serial: 23N5047F00839 Firmware: RAIDiator 4.2.28 Memory: 1024 MB [6-6-6-24 DDR2]
- StephenBJan 26, 2016Guru - Experienced User
I think you've ruled that out. If you want to be 100% certain you could try a direct connect. Maybe next time try rebooting the PC instead of the NAS, and see if it also recovers. How are you doing the copies?
Starlionblue3 wrote:
Maybe it has something to do with the networking between the switches...
I'll try rebooting the PC next time and we'll see.
I'm using TeraCopy for the file copies. However I have the same issue with Windows native file copy mechanism.
On a side note, TeraCopy is outstanding and is how the native Windows copy should work.
