krislee
Jul 08, 2015Aspirant
New disk in NV+ v2 and 'Volume expansion failed'
Good evening, I'd like to ask the members/experts about an expansion problem I'm having. I've done a search and suspect it's the usual 8TB volume expansion problem that seems to occur now and agai...
krislee
Jul 09, 2015Aspirant
Thanks StephenB.
I guess it's disk checking time via manufacturers tools and then a reset :(
To check the drives, is it as simple as turn the NAS off, remove each disk, connect to a spare SATA port on a PC, run the test and replace in same bay on the NAS? This won't break the current volume when I restart the NAS? There are a few items I need to add to my backup before I can reset the NAS.
Cheers,
Kris.
Cheers,
Kris.
