acugye
Jun 26, 2017Aspirant
New Red Harddrive not avaialbe for backupo
Hello, I recentyl added a new WDRed 4 TB drive to my 2 bay Ready Nas 102. It shows it to be in good health but it does to seem to be avasilbe for backup. I am using Bvckup2 to move data from my Win...
- Jun 29, 2017
One thing to note: With two separate volumes, you will have to manaully juggle the load between the two. Stephen has recommended doing that over a single RAID0 volume because if a drive goes bad, you'll only lose the data on the one, not both. I agree with that recommendation unless manual space juggling is just out of the question. With multiple computers to back up, you shouldn't have an issue doing the juggling.
Jun 26, 2017Guru - Experienced User
What size drive did you have installed before?
Are you using XRAID (the default) or one of the FlexRAID modes?
By default, XRAID will convert your existing volume from jbod to RAID-1 - giving you redundancy but no increase in storage.
