JasonCP
Dec 11, 2020Aspirant
New to NAS storage - total beginner, looking to set up a second hand Netgear ReadyNAS Duo v2
Dear community, This has probably been asked before. I did try and look but couldn't find anything. I have just bought a ReadyNAS Duo v2 off Ebay.There is a sticker on the bottom: FW v4.1.6. The mo...
- Dec 20, 2020
For others considering purchasing used, look at the picture of the rear of the Duo in question. If the fan is the full width of the chassis, it's a "real" V2. If the fan is smaller, and there is an depression where the power plugs in, it's a V1. Even on poor quality photos, these can usually be picked out.
Sandshark
Dec 20, 2020Sensei
ukbobboy01
Dec 21, 2020Apprentice
Hi Guys
Attached is a front pictures of the RNDuov2, unfortunately I can only add one picture per post and so cannot add a back picture as well.
UK Bob
- ukbobboy01Dec 21, 2020Apprentice
Here's the back picture I could not add in my previous post.
UK Bob
- StephenBDec 21, 2020Guru - Experienced User
Here's the front of the original Duo (v1). Note it just says "ReadyNAS Duo". The v2 looks the same from the front, except it says "Readynas Duo v2". The finish of the v1 is black - the v2 is more gray than black, but that might not be picked up in a photo.
The backs are definitely different, so if a rear photo is included it is easy to see which it is. Here is a side-by-side that compares the v2 back panel with the v1. The v1 (original) Duo is on the right.
Sorry fellas
Tried to cancel/delete this post but the system wouldn't let me.
UK Bob
