Kaleem
Sep 01, 2012Aspirant
Newbie - Novice requires Setup Advice
Hi, I'm a complete novice when it comes to NAS, Raid, etc, however have bought some kit, so would like some advice on the best setup for what I want to primarily use, which is: i) Media Stream...
Sep 23, 2012Guru - Experienced User
Upgrading the drive firmware has to be done on a PC (or perhaps on an x86 Mac with the Seagate boot disk). The Readynas has its own firmware, which should be kept current - but that is completely separate.
Whether you can upgrade the drives firmware depends on which ST3000DM001 variant you have. CC4H only applies to 9YN166, and per Seagate these drives would be running CC46, CC47, CC49, CC4C, or CC4G today. So I am thinking you might not have 9YN166. http://knowledge.seagate.com/articles/e ... Q/223651en
