Kaleem
Sep 01, 2012Aspirant
Newbie - Novice requires Setup Advice
Hi, I'm a complete novice when it comes to NAS, Raid, etc, however have bought some kit, so would like some advice on the best setup for what I want to primarily use, which is: i) Media Stream...
gibxxi
Nov 20, 2012Guide
Before the FW update my drive made an audibly head parking "click" noise about once a minute. But it's in a caddy in the main PC with air holes in, so it's very likely that this means it's a lot louder than it would be if buried in the case of the PC.
Since the update it makes the same "chirping" noise others have mentioned. It sounds like a drive doing a quick random seek once every minute or so for long periods. However, the SMART values are fine, and the drive is working flawlessly. Also, performance has improved a lot with the update, so now i've just gotten used to it "chirping" away in the background.
I did read somewhere that the drive has a feature built into the firmware that randomly tests every sector on the drive at random intervals on a cycle, to enable early notification of failure. But as this wasn't from an official source, it may or may not be the case.
