julesg1's avatar
julesg1
Tutor
Oct 31, 2011
NFS problems with Ubuntu 10.10
Hello,
I recently installed Ubuntu 10.10 on an old PowerMac G5 (PPC) and am now trying to mount the shares I have on my ReadyNAS NV+ box. I have several shares set up, one called "media" which is set up for read only default access for NFS and another share called "Data" which is set up for disabled default access for NFS but I have enabled write and root privileges for a group called LWDG. The problem I'm having is that I can mount the "media" share but am getting an "access denied" error when I try to mount the "Data" share. On the NV+ the user "jules" has UID 1004 and group "LWDG" has GID 100. I have already changed my UID and GID for my Linux login to match the UID and GID for the NV+ account I want to use but am still getting the same error. I did a search on this forum for similar issues but have not been able to resolve my problem from the other threads. I'm very new to Linux so I would appreciate any help anyone can give me. I am using RAIDiator 4.1.8. I have added code and tried adding screenshots but can't figure out how to do this:
jules@jules-desktop:~$ showmount -e 192.168.1.110
Export list for 192.168.1.110:
/c/home *
/c/media *
/USB/USB_BACKUP_2 *
/c/Data LWDG
/c/Archive LWDG
/c/UserSettings LWDG
jules@jules-desktop:~$ sudo mount -t nfs 192.168.1.110:/media /home/jules/LWDG/media
[sudo] password for jules:
jules@jules-desktop:~$ sudo mount -t nfs 192.168.1.110:/Data /home/jules/LWDG/Data
mount.nfs: access denied by server while mounting 192.168.1.110:/Data
jules@jules-desktop:~$ id jules
uid=1004(jules) gid=100(users) groups=100(users),4(adm),20(dialout),24(cdrom),46(plugdev),111(lpadmin),119(admin),122(sambashare)
  • ewok's avatar
    ewok
    NETGEAR Expert
    LWDG is a group name? NFS can only be restricted by hostname or IP address.
    Yes, LWDG is a group name. So how do I resolve this?
  • Remove LWDG from the enabled hosts dialog in the NFS settings for the share
  • Thanks sphardy, that's easy enough :-)
    Similarly though, I have "private home shares" enabled in the user preferences and have "Export home shares over NFS" enabled as well. I have not been able to access these shares via NFS or AFP (using mount_afp) with Linux but I have no problem using AFP with Mac OS 10.5. Any idea why?
  • You would have to show how you are trying to mount the home shares
