jsauser11
Apr 04, 2016Aspirant
No Admin Page and Power Button Reset Does not work.
I am using a Readynas R104 with 6.4.2 firmware. The past 2 days, the admin page refuses to appear from a web browser, and when trying to reboot via the power button, nothing happens (no information d...
- Apr 12, 2016
Problem seems to have gone away, running stable for several days now.
I am on OS6 and have logs from when the problem was happening. Would you like them?
Apr 04, 2016Guru - Experienced User
You could enable ssh, and if that responds you can do a restart (or a shutdown) from there.
If the antivirus service enabled? If so, disable it.
jsauser11
Antivirus is not enabled. Can you provide a link to instructions for enabling ssh and initiation of reboot from ssh?
Also, what do you think the root cause of the loss of admin page and power button response is? Is it a known issue with this firmware version that could be addressed by using a later version beta?
Thanks for the quick response to the issue.
Jeff
- StephenBApr 04, 2016Guru - Experienced User
You enable ssh from the system->settings page (in the services section). Once enabled, you connect with putty (or equivalent). The username is root, the password is the NAS admin password.
You shut down with rn_shutdown now You can reboot with reboot -p
- jsauser11Apr 04, 2016Aspirant
Thanks. I will give that a try. Still would like to eliminate the root problem. Maybe next firmware will fix it.
Installed Putty and hard reset ReadyNAS with power disconnect. After reboot, enabled ssh access from admin page and tested reboot via putty with success.
Thanks for the help. Hope I can get the issue sorted so I don't have to keep rebooting!
