Ringo155
Apr 01, 2017Aspirant
No apps work / can be installed / deleted after Firmware re-install
Hi everbody, due to a forgotten password I followed the advice to reinstall Os 6.6.1. This actually worked well and I was able to set a new password. But something must have gone wrong, as I no...
- Apr 02, 2017
You've run into an issue that's fixed in ReadyNAS OS 6.7.0 which is now available!
mdgm-ntgr
Apr 02, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- Ringo155Apr 02, 2017Aspirant
Just sent them!
Thanks for your help!
- mdgm-ntgrApr 02, 2017NETGEAR Employee Retired
Great! Thank You!
I'll directly try it :-)
