Ringo155
Apr 01, 2017Aspirant
No apps work / can be installed / deleted after Firmware re-install
Hi everbody, due to a forgotten password I followed the advice to reinstall Os 6.6.1. This actually worked well and I was able to set a new password. But something must have gone wrong, as I no...
- Apr 02, 2017
You've run into an issue that's fixed in ReadyNAS OS 6.7.0 which is now available!
mdgm-ntgr
Apr 02, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
Ringo155
Apr 02, 2017Aspirant
Just sent them!
Thanks for your help!
- mdgm-ntgrApr 02, 2017NETGEAR Employee Retired
- Ringo155Apr 02, 2017Aspirant
Great! Thank You!
I'll directly try it :-)
