Joene1984
Nov 21, 2012Aspirant
No USB Share after connecting USB disk
Hello, i have a ReayNAS Duo. I use an external USB drive to backup some files from the readynas. The USB drive gets automatically a Windows share called USB_HDD_1 or USB_HDD_2 for a second USB dr...
ReadySECURE
Nov 21, 2012Apprentice
What version of the firmware are you using?
When you go into FrontView, Volumes > Volume Settings, do you see the USB down at the bottom? If so, what does it say about the USB disk? What kind of USB are you using? What operating systems do you use to access this USB device? What file system is on the USB drive?
