Joene1984
Nov 21, 2012Aspirant
No USB Share after connecting USB disk
Hello, i have a ReayNAS Duo. I use an external USB drive to backup some files from the readynas. The USB drive gets automatically a Windows share called USB_HDD_1 or USB_HDD_2 for a second USB dr...
Joene1984
Nov 28, 2012Aspirant
I have tested it with 3 usb devices and all have the same. The share volume stays at USB_HDD_5 and doesn't change. Even if there's no USB device connected it says USB_HDD_5 is on.
RAIDiator 4.1.6 [1.00a043]
At the volumes i only see the Harddisks. When i open the USB tab i see the USB device (USB HDD5, with no unmount option). Even if there's no usb device connected it shows an USB device.
FAT32/NTFS
readysecure1985 wrote: What version of the firmware are you using?
readysecure1985 wrote: When you go into FrontView, Volumes > Volume Settings, do you see the USB down at the bottom? If so, what does it say about the USB disk? What kind of USB are you using?
What file system is on the USB drive?[/quote]
readysecure1985 wrote: What operating systems do you use to access this USB device?
I use Windows 7
FAT32/NTFS
