rantech
May 24, 2017Aspirant
Noisy Seagate Ironwolf 6TB drives
I recently bought my 4th ReadyNAS box (a 524) after having three older models on OS 4.2.30. I installed Seagate Ironwolf 6TB drives in the 524 but I am getting a lot of noise from the drives - parti...
rantech
All drives have firmware SC61 and are Model ST6000VN0041-2EL11C
mdgm-ntgr
May 24, 2017NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- rantechMay 24, 2017Aspirant
Logs and audio recordings of noise submitted
- StephenBMay 25, 2017Guru - Experienced User
You might also contact Seagate. There was a similar noise issue reported with the Ironwolf 8 TB drives, and Seagate provided a drive firmware upgrade.
- rantechMay 31, 2017Aspirant
I bought (4) new Western Digital Red 6 TB Drives and I swapped them out one at a time and let the 524 resync after each disk (just finished this morning). There is now no discernable additional noise from the box at all either during disk spin-up or operation. I was in touch with seagate and hopefully with this information, they'll replace the ironwolf drives.
