Getsuruito
Aug 10, 2017Aspirant
Not able to access Admin Page after OS reinstall (RN104)
Hi, I had to OS reinstall my RN104 because I forgot the Admin Password. But since then I can no longer access the Admin Page (Using admin/password credentials). It's giving me "Internal Server Er...
- Sep 04, 2017
Looks like your NAS unit's time was set back to epoch time 0 after you updated to 6.4.0 and on each OS Re-install it was still showing that as well. I've now fixed the hardware clock and updated the firmware on the unit first to 6.5.2 and then onto 6.8.0
[2015/03/21 10:07:50] Factory default initiated due to new disks (no RAID, no partitions)! [2015/03/21 10:08:11] Defaulting to X-RAID2 mode, RAID level 1 [2015/03/21 10:08:39] Factory default initiated on ReadyNASOS 6.1.9 (1409791183). [2015/03/21 10:23:40] Updated from ReadyNASOS 6.1.9 () to 6.2.2 (ReadyNASOS). [2016/03/13 12:23:13] Updated from ReadyNASOS 6.2.2 (ReadyNASOS) to 6.2.2 (ReadyNASOS). [1969/12/31 17:00:57] Updated from ReadyNASOS 6.2.2 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [1969/12/31 17:00:55] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.0 (ReadyNASOS). [2017/09/04 04:07:15] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.5.2 (ReadyNASOS). [2017/09/04 10:14:57 UTC] Updated from ReadyNASOS 6.5.2 (ReadyNASOS) to 6.8.0 (ReadyNASOS).
Now, I think you should be able to login with the default password. If not, try another OS Re-install.
One of your disks has 8 ATA errors and a single current pending sector. I'd keep an eye on that disk.You're using a single RAID-0 volume spanning both disks. That's quite risky. If either disk fails all data will be lost.
Getsuruito
I'm using 6.4.0 Firmware.
When I use https://nas-ip-address/fwbroker I receive the same "500 Internal Server Error message".
Aug 10, 2017Guru - Experienced User
You might need to do a USB recovery. I'd wait for mdgm-ntgr to chime in before trying that though.
6.4.0 is quite old, when you get the system back up I recommend upgrading to 6.8.0 (the current release).
- GetsuruitoSep 03, 2017Aspirant
Hi Guys,
My problem still persists.
Please help.
Thanks.
- mdgm-ntgrSep 04, 2017NETGEAR Employee Retired
- GetsuruitoSep 06, 2017Aspirant
Thanks mdmg, it's working fine now. I'll monitor the disk and will try to change the RAID type to a more safe config.
Thanks again.
