drgonzoishere
Jan 20, 2012Aspirant
"Not enough space on NAS..."
**Can't find the correct thread to post this in, so please move it if it shouldn't be in here** Problem: I'm unable to transfer large files onto my NAS2000, I keep getting the not enough space erro...
Jan 20, 2012Guru - Experienced User
You mean backup and media? Or something else? Since you are using two Raid 0 volumes, each share is on one specific volume.
I don't recall off hand how to tell which share is on which volume (my 3 NAS are all set up with one volume).
Assuming you are writing to folders that are listed in the "shares" list, maybe you should open a support case.
