RichardEynon
Jan 14, 2014Aspirant
Not Redundant Message after Boot
I'm having the same issue with my ReadyNas NV+ v2. I've had it a long time but just ignored the error only as long as I don't reboot, I have 2 x 2TB WD HD's in it, giving me an 2TB array that was redu...
Jan 14, 2014Guru - Experienced User
I'd begin by backing it up!
Do you know for sure this is a v2? The labels are misleading - check this guide: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If you do have a v2, and are the original purchaser, then you are still entitled to netgear support (warranty is 3 years, and the v2 hasn't been out that long). So you could enter a support request at support.netgear.com. They would probable need remote access to the unit.
