nglshmn
Aug 17, 2016Tutor
[null]+2 on RN314 Display
Started failing to attach to shares across SMB, and unable to get to admin page via HTTPS. The only option was to reboot the NAS. When finished booting it displayed [null]+2 on the case display. ...
- Aug 21, 2016
Any update?
That particular error message on the display in this instance appears from your logs to relate to the p2p network ReadyCLOUD uses crashing.
mdgm-ntgr
Aug 17, 2016NETGEAR Employee Retired
Can you send in the logs zip file (see the Sending Logs link in my sig)?
