nglshmn
Aug 17, 2016Tutor
[null]+2 on RN314 Display
Started failing to attach to shares across SMB, and unable to get to admin page via HTTPS. The only option was to reboot the NAS. When finished booting it displayed [null]+2 on the case display. ...
- Aug 21, 2016
Any update?
That particular error message on the display in this instance appears from your logs to relate to the p2p network ReadyCLOUD uses crashing.
mdgm-ntgr
Aug 17, 2016NETGEAR Employee Retired
Can you send in the logs zip file (see the Sending Logs link in my sig)?
nglshmn
Aug 17, 2016Tutor
Thanks mdgm.
Log files sent via pm.
Tim
- mdgm-ntgrAug 17, 2016NETGEAR Employee Retired
Thanks for the logs.
Do you have a backup? If not, you could try booting into volume read-only mode (a boot menu option) and see if you can backup your data when booted into that.I can see that your data volume is ~89% full which is starting to get pretty full.
You last did a factory reset on 6.0.8 back in December 2013 when you first got the NAS.I can see a huge amount of metadata on this system. This is likely due to fragmentation from having CoW (Copy-on-Write) enabled and probably at some point having snapshots (which use CoW at the point in time the snapshots were taken even if CoW is disabled on the share) on shares that don't have any snapshots now. You do have snapshots on your Amazon Cloud Drive share but that share obviously must be pretty new as backing up to Amazon Cloud Drive is a new feature.
From 6.2.0 onwards it has been possible to disable CoW (we link enabling/disabling CoW to enabling/disabling bit-rot protection but they are two separate things).Considering the age of your volume and the high level of fragmentation it would be advisable to backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup.
You should be selective as to which shares you use with CoW and snapshots.
Also, please in future if logs are requested include a link to your thread as per the instructions. It wasn't a problem this time as you sent them so promptly but it does help to quickly locate which thread the logs refer to.
- nglshmnAug 17, 2016Tutor
Ugh. I was hoping to avoid a backup and restore, given the size of the data.
In read-only mode will I have SMB access? If so, I can backup the data that doesn't exist elsewhere (About 2Tb). Most of this NAS is actually a backup of my Main NAS!
I really don't want CoW, so will need to look into that closer to see how to turn it off.
Sorry about forgetting the link. Not deliberate.
Thanks for the help. What does the [null]+2 mean, as a matter of interest?
Tim
You should be able to access it via SMB in that mode, yes.
It's part of a critical kernel error message. Whilst I think that particular message doesn't tell us much, sometimes the snippet of an error message can be closely associated with a problem giving us a clearer indication if users have the same problem in common.
