nglshmn
Aug 17, 2016Tutor
[null]+2 on RN314 Display
Started failing to attach to shares across SMB, and unable to get to admin page via HTTPS. The only option was to reboot the NAS. When finished booting it displayed [null]+2 on the case display. ...
- Aug 21, 2016
Any update?
That particular error message on the display in this instance appears from your logs to relate to the p2p network ReadyCLOUD uses crashing.
nglshmn
Aug 17, 2016Tutor
Ugh. I was hoping to avoid a backup and restore, given the size of the data.
In read-only mode will I have SMB access? If so, I can backup the data that doesn't exist elsewhere (About 2Tb). Most of this NAS is actually a backup of my Main NAS!
I really don't want CoW, so will need to look into that closer to see how to turn it off.
Sorry about forgetting the link. Not deliberate.
Thanks for the help. What does the [null]+2 mean, as a matter of interest?
Tim
mdgm-ntgr
Aug 21, 2016NETGEAR Employee Retired
Any update?
- nglshmnAug 29, 2016Tutor
Thanks mdgm. Sorry for the tardy response.
I started by booting into read-only mode so I could validate that my backup was good. It still crashed once - it appears that the disks had gone to sleep and I couldn't wake them. Then I noticed your post. I decided to risk it, and not wipe the NAS until I had tried an experiment.
I turned off ReadyCLOUD on the Cloud tab in the admin interface and it has been running fine in read-only mode ever since. About a week now.
I'm going to try the same thing in normal boot mode and will report back, but it's looking (at the moment) as though ReadyCLOUD is potentially the issue.
Perhaps, once I've experimented I'll wipe it anyway for the reasons you mentioned.
I'm running NASOS 6.5.1 BTW.
Thanks,
Tim
