Bardeaux
Sep 17, 2014Aspirant
NV + v2 Not upgrading (rebuild)
I had to challenges this summer: I received capacity warnings and had reoccurring disk problems. I used to have two 3Tb disks in X-raid, and decided to get two 4Tb disks in addition to the old ones...
Sep 17, 2014Guru - Experienced User
I'd try rebooting. If that doesn't help, then contact support (support.netgear.com, use email). You should still be under warranty if you are the original purchaser.
