Bardeaux
Sep 17, 2014Aspirant
NV + v2 Not upgrading (rebuild)
I had to challenges this summer: I received capacity warnings and had reoccurring disk problems. I used to have two 3Tb disks in X-raid, and decided to get two 4Tb disks in addition to the old ones...
RVTJR
Hi Bardeaux,
Not sure but I think this is the 8Tb limit expansion issue of EXT filesystem. Someone should confirm this as I am not 100% sure. :)
If this is really the case, you will need to get your data out of the NAS, do a factory reset. Put your files back.
