Bardeaux
Sep 17, 2014Aspirant
NV + v2 Not upgrading (rebuild)
I had to challenges this summer: I received capacity warnings and had reoccurring disk problems. I used to have two 3Tb disks in X-raid, and decided to get two 4Tb disks in addition to the old ones...
Sep 17, 2014Guru - Experienced User
If you started with 2x3TB and then expanded to 2x3TB+2x4TB, then you are going from a 3 TB volume to a 10 TB volume. That expansion is 7 TB, under the 8 TiB growth limit.
So I don't think that's the issue here - unless you started with something smaller than 2x3TB (say 2x1TB).
In any event, if rebooting doesn't help, contact support. They will be able to tell you if you hit the expansion limit.
