mchinand
May 02, 2012Aspirant
NV+ boot problems after replacing bad disk (ref #18488016)
After replacing a bad disk (disk 2 in a 4 disk x-raid configuration), my system rebuilt to 85% and stopped. It now won't boot; screen stuck on "Booting..." with solid power button lit. I took disk 1 o...
mdgm-ntgr
May 16, 2012NETGEAR Employee Retired
One thing you could try is cloning disk 1 onto a new disk using dd_rescue. Not guaranteed to work but definitely worth a try.
If you haven't already I would also suggest testing the other disks using manufacturer's diagnostic tools as well (be sure to label the order of the disks so you put them back in the correct slots).
So did you purchase the NAS new before August 21, 2007? If not when did you purchase it?
readysecure1985 wrote: you could always use knoppix to clone the drive to a known good drive, and then place it back in the device. Keep in mind that the known good drive should be on the HCL. After successfully cloning with knoppix, you can then place the good drive in the NAS and power on. If all goes well, it will be as though the drive did not have any issues.
Here is a simple guide to quickly recover a failed drive using dd_rescue.
I often have to deal with pesky failed drives, so here is a quick simple guide how to achieve this with a free Linux Live CD and a PC with two SATA connections.
I will be using a Knoppix 6.2 Live CD for this guide. Can be found at http://www.knoppix.net
Using dd_rescue command allows you to copy data from one drive to another block for block. This is especially useful for recovering a failed drive. Often when a drive fails, the drive is still accessible, it has just surpassed the S.M.A.R.T. error threshold. dd_rescue allows you to ignore the bad sectors and continue cloning the bad drive to a new healthy drive.
1) Connect your old drive and new drive to your PC
2) Boot up using your Linux live CD
3) Launch a terminal window.
4) Run fdisk -l to make sure the system sees both of the hard drives.
5) Run hdparm -i /dev/sdx on both of the drives to find which drive is your source drive and which drive is your destination drive
6) Once you know which drive is which you can start the clone process.
dd_rescue /dev/sdx(source disk) /dev/sdx(destination drive)
7) You will see the process start, just keep an eye on it, it might take a few hours for the clone job to finish, depending on the size of the drive.
Once the process is complete, there will be no notification, the transfer will just stop and you will see the terminal prompt again.
If you see a lot of errors or see that there is no more data being shown as succxfer: it means the drive got marked faulty by the kernel. At this point reboot the system and make sure you know which drive is which again, as it is possible they lettering might switch. Run the dd-rescue command again but this time with -r option. This will start the cloning again but this time will start from the back of the drive and will make sure to get the data that has not been cloned yet.
There is no guarantee this will recover your data, but there is a very high chance this will work and its free…
