simonsbk
Aug 04, 2014Follower
NV+ default password doesn't work
Hi I am New User I have inherited from and old IT company a ReadyNAS NV+, I ham trying to reset it which have done and I can see the shares using the unc path and IP but I cannot see how I can chan...
mdgm-ntgr
Aug 04, 2014NETGEAR Employee Retired
What do you see in the info (far right) column in RAIDar?
Can you confirm which NV+ you have?: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Sounds like you probably have a v1 which has a different default password to the v2.
