somejoe
Jan 20, 2013Aspirant
NV+ disk swap failure
I was running out of room, was going to upgrade from 500MB to 2TB drives. Using WD RED, so compatible. Pulled the first disk and put in the new one. Ran through initialization, started sync, got to...
somejoe
Jan 21, 2013Aspirant
I pulled the new disk and rebooted the NV+. It performed an FS check and came up - of course with the warning that it's now unprotected and a disk failure will be catastrophic. I've done a full backup and am going to now try loading the new disks and doing a factory reset. Thanks for the suggestion.
