somejoe
Jan 20, 2013Aspirant
NV+ disk swap failure
I was running out of room, was going to upgrade from 500MB to 2TB drives. Using WD RED, so compatible. Pulled the first disk and put in the new one. Ran through initialization, started sync, got to...
mdgm-ntgr
Jan 22, 2013NETGEAR Employee Retired
What version of RAIDiator is on your unit. If it is not already 4.1.7 or later you will want to do another factory default after updating the firmware.
